Madsonic 5.1 unRAID Plugin
http://lime-technology.com/
Contribution: http://lime-technology.com/forum/index. ... ic=21356.0 developed by jangjong
Download: https://code.google.com/p/unraid-subson ... loads/list
Picture Gallary Madsonic on unRAID Gallery Link
madsonic-5.1-1.8-x64.plg
madsonic-5.1-1.8-x86.plg
Version 1.8
- Update: Java JRE to 1.7_67
- Update: Madsonic Build 5060
- Update: x64 ffmpeg fix
- Update: Java JRE to 1.7_60
- Update: Madsonic Build 3880
- Update: Madsonic Build 3860
- support x64 unRaid 6.x Beta
- Update to Google Repository
- Update: split: jetty6/8 build installation
- Update: Java JRE to 1.7_51 package
- Bugix: looped install
- Update: ffmpeg package
- Update: Java JRE to 1.7.45 package
- Update: back-porting madsonic.war & madsonic-booter.jar to jetty 6.1.x server
This version has known issues and is only for testing purpose !
Download & Installation
Repository
https://code.google.com/p/unraid-madson ... owse/trunk
x86 backported jetty 6.1.x version
cd /boot/config
mkdir plugins
cd plugins
wget --no-check-certificate http://unraid-madsonic-plugin.googlecode.com/svn/trunk/madsonic-5.0-1.6-x86-jetty6.plg
installplg madsonic-5.0-1.6-x86-jetty6.plg
cd /boot/config
mkdir plugins
cd plugins
wget --no-check-certificate http://unraid-madsonic-plugin.googlecode.com/svn/trunk/madsonic-5.0-1.6-x86-jetty8.plg
installplg madsonic-5.0-1.6-x86-jetty8.plg
cd /boot/config
mkdir plugins
cd plugins
wget --no-check-certificate http://unraid-madsonic-plugin.googlecode.com/svn/trunk/madsonic-5.1-1.8-x64.plg
installplg madsonic-5.1-1.8-x64.plg
cd /boot/config
mkdir plugins
cd plugins
wget --no-check-certificate http://unraid-madsonic-plugin.googlecode.com/svn/trunk/madsonic-5.1-1.8-x86.plg
installplg madsonic-5.1-1.8-x86.plg
Requirement for virtual testing
- Virtualbox Download https://www.virtualbox.org/wiki/Downloads
- unRAID 5.0.4 VMDK Images Download http://lime-technology.com/forum/index. ... ic=26639.0
- unRAID 5.0.4 Installation Download http://lime-technology.com/download/
* Create new virtual machine as linux -> ubuntu x86 machine type
* set the network card-type to network-bridged and realteak as brand
* add the unRAID virtual disk as primary disc and add others for your drive store
* create USB Installation disk http://lime-technology.com/unraid-server-installation
* start virtual machine and check online connectivity
* try to start download or install
Known issues
- after installation the transcoding profil needs to be reseted to subsonic default
