Madsonic Server 5.0 unRAID Plugin
Post by Madsonic »
Madsonic 5.1 unRAID Plugin
http://lime-technology.com/
Contribution: http://lime-technology.com/forum/index. ... ic=21356.0 developed by jangjong
Download: https://code.google.com/p/unraid-subson ... loads/list
Image Image Image Image
Picture Gallary Madsonic on unRAID Gallery Link
madsonic-5.1-1.8-x64.plg
madsonic-5.1-1.8-x86.plg
Version 1.8
  • Update: Java JRE to 1.7_67
  • Update: Madsonic Build 5060
  • Update: x64 ffmpeg fix
Version 1.6
  • Update: Java JRE to 1.7_60
  • Update: Madsonic Build 3880
Version 1.5
  • Update: Madsonic Build 3860
Version 1.4
  • support x64 unRaid 6.x Beta
Version 1.3
  • Update to Google Repository
Version 1.2
  • Update: split: jetty6/8 build installation
Version 1.1
  • Update: Java JRE to 1.7_51 package
  • Bugix: looped install
Version 1.0
  • Update: ffmpeg package
  • Update: Java JRE to 1.7.45 package
  • Update: back-porting madsonic.war & madsonic-booter.jar to jetty 6.1.x server
This version has known issues and is only for testing purpose ! ;)
Download & Installation
Repository
https://code.google.com/p/unraid-madson ... owse/trunk
x86 backported jetty 6.1.x version
cd /boot/config
mkdir plugins
cd plugins
wget --no-check-certificate http://unraid-madsonic-plugin.googlecode.com/svn/trunk/madsonic-5.0-1.6-x86-jetty6.plg
installplg madsonic-5.0-1.6-x86-jetty6.plg
or x86 default jetty 8.1.x version
cd /boot/config
mkdir plugins
cd plugins
wget --no-check-certificate http://unraid-madsonic-plugin.googlecode.com/svn/trunk/madsonic-5.0-1.6-x86-jetty8.plg
installplg madsonic-5.0-1.6-x86-jetty8.plg
or new Madsonic 5.1 Public Preview x64
cd /boot/config
mkdir plugins
cd plugins
wget --no-check-certificate http://unraid-madsonic-plugin.googlecode.com/svn/trunk/madsonic-5.1-1.8-x64.plg
installplg madsonic-5.1-1.8-x64.plg
or new Madsonic 5.1 Public Preview x86
cd /boot/config
mkdir plugins
cd plugins
wget --no-check-certificate http://unraid-madsonic-plugin.googlecode.com/svn/trunk/madsonic-5.1-1.8-x86.plg
installplg madsonic-5.1-1.8-x86.plg
Requirement for virtual testing
* Create new virtual machine as linux -> ubuntu x86 machine type
* set the network card-type to network-bridged and realteak as brand
* add the unRAID virtual disk as primary disc and add others for your drive store
* create USB Installation disk http://lime-technology.com/unraid-server-installation
* start virtual machine and check online connectivity
* try to start download or install
Known issues
  • after installation the transcoding profil needs to be reseted to subsonic default
Lars
binhex
Been thanked: 5 times
Re: Madsonic Server 5.0 unRAID Plugin
Post by binhex »
im trying to get video transcoding going but im getting the following error in madsonic android app:-
"no activity found to handle intent", maybe there has been a change to bsplayer but it doesnt work for me right now.
binhex
Post by binhex »
found out what the issue is, i have specified my server to use https, looks like BSPlayer cannot playback a https stream, or at least it can't from madsonic, any chance of a fix?.
These users thanked the author binhex for the post:
binhex
Post by binhex »
hey fergalc, yep i am using my own plugin, however it SHOULD work with mad's version, just make sure you switch the ports around in the unraid plugin settings, so set port number for http to 0 and then set https to the port you had previously set for http, so for me i have:-
HTTP Port for Madsonic Web Server: 0
HTTPS Port for Madsonic Web Server:3030 (my choice)
i can then connect via https://tower:3030
obviously if external you would use your assigned internet facing ip and setup port forwarding your router etc.
binhex
Post by binhex »
btw madevil if your following this then i have resolved the streaming issue over https by switching player to mxplayer, looks like this is fine with https streams, thought i would just let you know, might be nice to catch that error and display a more user friendly "bsplayer does not support https" message though perhaps?
binhex
Post by binhex »
thats odd, as stop and start (enable/disable in plugin ui) work fine for the plugin im using, im still surprised your not running into the other two issues i mentioned on the unraid forum
Post by Madsonic »
unRAID Update:
madsonic-5.0-1.2-jetty6.plg
madsonic-5.0-1.2-jetty8.plg
Bugfix, JRE Update
binhex
Post by binhex »
hi madevil, i see you incorporated my posted fixes for the plugin, nice :-).
Post by Madsonic »
binhex wrote:hi madevil, i see you incorporated my posted fixes for the plugin, nice :-).
Yes thanks, works great now! :)
i upload a version for subsonic 4.9 too.
binhex
Post by binhex »
my pleasure guys :-), one more thing you might want to tweak on the plugin is to change the max memory default, i think if im right its 350 MB by default in madsonic.sh?, so probably best to set the plugin to be the same wouldn't you agree, currently its set to 100MB and also incorrectly 128 MB (line 53) in your plugin, check lines 53, 227, 363 of your latest jetty8 plugin.
edit - confirmed, here are the defaults for init and max memory:-
MADSONIC_INIT_MEMORY=256
MADSONIC_MAX_MEMORY=350
Post by Madsonic »
i don't know how much is the average used memory on unRAID server ?
i keep this settings low to prevent errors.
on the Settingspage you can define your needs for init/max memory setup.
Info http://javarevisited.blogspot.co.at/201 ... e-jvm.html
mrdrew
Post by mrdrew »
I see that you split somethin called jetty6 and jetty8.
What are those? Does it matter which one I use? I didn't see an explanation anywheres.
When downloading this PLG, be sure to get the "raw version" of the plg, so you don't accidentally wget a webage with the plg (whoops).
Post by Madsonic »
mrdrew wrote:I see that you split somethin called jetty6 and jetty8.
Jetty is an HTTP server, HTTP client, and java servlet container.
Jetty is the default embedded Web-server for Madsonic or you can use tomcat instead.
Jetty6 is old but good for modding,
Jetty8 is better for performance.
http://www.eclipse.org/jetty/
binhex
Post by binhex »
Madevil wrote:hi there,
i would say a majority of people have 4GB of ram, the amount used will obviously depend on the number of plugins people have running, i understand you want to keep memory requirements low to begin with, i still think you need to review the setting in the plugin though as you have a mismatch, at the top of the plugin on line 53 you specify 128MB of ram, but later on its referencing 100MB of ram on lines 227 and 363, so might be worth tweaking these?.
ootuoyetahi
Post by ootuoyetahi »
I know this isnt the subsonic forum, but since you posted the subsonic unraid package could someone help me install it? This is literally the first unraid package I am attempting to install.
Thanks.
ootuoyetahi
fergalc wrote:
ootuoyetahi wrote:I know this isnt the subsonic forum, but since you posted the subsonic unraid package could someone help me install it? This is literally the first unraid package I am attempting to install.
Thanks.
In essence, it's the same install as Madsonic:
cd /boot/config
mkdir plugins
cd plugins
wget --no-check-certificate h**p://unraid-madsonic-plugin.googlecode.com/svn/trunk/subsonic-4.9-1.0.plg
installplg subsonic-4.9-1.0.plg
Replace both ** above with tt
Hope that helps..!
Best regards, fergal
Thanks a ton! I swear I tried this, and It didnt work but i copied and pasted your example and it worked. I probably fat fingered something, but nonetheless, thank you for your help ;-)
ootuoyetahi
Thanks.
cd /boot/config
mkdir plugins
cd plugins
Hope that helps..!
I do get this error after launching it:
HTTP ERROR: 404
NOT_FOUND
RequestURI=/
Powered by jetty://
Any ideas?
ootuoyetahi
fergalc wrote:
fergalc wrote:
HTTP ERROR: 404
NOT_FOUND
RequestURI=/
Powered by jetty://
Any ideas?
are you installing Subsonic to your cache drive? If so, check the Subsonic folder and see what got installed in there...
I've just installed it on mine and it's coming up, no problems. Mind you, mine was a fresh install, are you installing it on top of jangjangs subsonic?
I'm installing it on a fresh unRAID installation as well in a virtual environment I set up just to test these before I move them to the production box. I installed it a second time and am getting the same issue. I am a little confused about what you mean when you ask if I am installing it on my cache drive. It gets installed on the flash, no?
EDIT: here are links to what the config looks like and the error I get.
http://i.imgur.com/l9DoMya.png
http://i.imgur.com/ayzBbm0.png
EDIT2:
It works if I keep the default ports. Unfortunately, I have something using that port already. Is it possible to use nonstandard ports and have this work?
ootuoyetahi
Thanks a ton fergalc, I got it working. I didnt really do anything other than stop it and start it a few times, but whatever the issue was has gone away. Now I can test :D
Thanks again for your help.
bdavis0185
Post by bdavis0185 »
Just wanted to stop in and say that the Subsonic UnRAID plg is working great, keep up the great work!!!
