I have lots of art folders within my album and artist folders and these folders then show up on my Home page. Be good if there was an option to exclude these folders from scans, the existing exclude options don't appear to work at folder level.
Exclude art folders from scans
- kmil992000
- Been thanked: 4 times
- These users thanked the author kmil992000 for the post:
Re: Exclude art folders from scans
Workaround: Change the security rights on your Art Folders, so Madsonic is not able to read them.
Greetings Kae
Greetings Kae
- These users thanked the author KaeTuuN for the post:
- kmil992000
- kmil992000
- Has thanked: 1184 times
- Been thanked: 465 times
We'll add a setting that lets you define folders to exclude when scanning your library.
- These users thanked the author Madsonic for the post (total 2):
- kmil992000 • Matt Zornig
- Rating: 15.38%
It's added in the last 7.0.10390 build.
- kmil992000
I'll guess, you have to try yourself :-)
But as fas as I can see in -> Settings -> Media Folders you can use regex to create crazy patterns. Multiline Textfield would be so much easier for nun regex-users :-) But then, others will complain about missing flexibilities...
Try the | to add an OR expression, like (Extrathumbs) | (Extrafanart)
Maybe this helps for starting?
Online regex tester and debugger
Regex match folder and all subfolders
- These users thanked the author Matt Zornig for the post (total 2):
- kmil992000 • Madsonic
- Rating: 15.38%
- kmil992000
I use this expression and works well for me. You may need to amend it depending on your requirements and folder names:
(?i)scan\w$|(?i)cover\w|(?i)artwork$|(?i)scans covers$|(?i)album[ ](?i)art$|(?i)art$|(?i)images$|(?i)scans[ ](?i)deluxe$
