Left Nav Errors
Left Nav Errors
After rebooting my 2012R2 box post MS updates I logged back into Madsonic and am now getting the following errors. It had been working fine prior to reboot. I have restarted the service logged in as admin but still the same errors. See attached error text and log file
- Attachments
madsonic.log- Log file
- (23.92 KiB) Downloaded 546 times
Error.txt- errors from left Nav
- (11.61 KiB) Downloaded 552 times
Re: Left Nav Errors
I get also left nav errors. One was caused by removing one folder in music folders.
I did some tests and I manage to focus the problem to Access rights.
None of my users are not in ALL-group so i disabled the Access rights on this group. Then left nav error start.
I enabled Access rights to group ALL Madsonic starts working normally.
I thing there is something wrong in Groups handling because you can´t name them differently from default naming or the groups cannot be deleted.
Deleting gives this error:
I´m running version:
MADSONIC 5.2.5250.20141025.1033
Apache Tomcat/8.0.14, java 1.8.0_25, Windows 7
Br
-m-
Exception org.springframework.dao.DataIntegrityViolationException
Message PreparedStatementCallback; SQL [delete from user_group where id=?]; integrity constraint violation: foreign key no action; FK_GROUP_ID table: USER; nested exception is java.sql.SQLIntegrityConstraintViolationException: integrity constraint violation: foreign key no action; FK_GROUP_ID table: USER
Java version Oracle Corporation 1.8.0_25
Operating system Windows 7 6.1
Server Apache Tomcat/8.0.14
Memory Used 632 of 742 MB
Stack trace org.springframework.dao.DataIntegrityViolationException: PreparedStatementCallback; SQL [delete from user_group where id=?]; integrity constraint violation: foreign key no action; FK_GROUP_ID table: USER; nested exception is java.sql.SQLIntegrityConstraintViolationException: integrity constraint violation: foreign key no action; FK_GROUP_ID table: USER
at org.madsonic.dao.AbstractDao.update(AbstractDao.java:71)
at org.madsonic.dao.GroupDao.deleteGroup(GroupDao.java:70)
at org.madsonic.service.SecurityService.deleteGroup(SecurityService.java:259)
at org.madsonic.controller.GroupSettingsController.handleParameters(GroupSettingsController.java:87)
at org.madsonic.controller.GroupSettingsController.handleRequestInternal(GroupSettingsController.java:47)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:919)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:851)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:855)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:644)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:725)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:291)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:219)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:506)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:142)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:610)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:537)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1081)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:658)
at org.apache.coyote.http11.Http11NioProtocol$Http11ConnectionHandler.process(Http11NioProtocol.java:222)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1566)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1523)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
Caused by: java.sql.SQLIntegrityConstraintViolationException: integrity constraint violation: foreign key no action; FK_GROUP_ID table: USER
... 83 more
Caused by: org.hsqldb.HsqlException: integrity constraint violation: foreign key no action; FK_GROUP_ID table: USER
at org.hsqldb.StatementDML.performReferentialActions(Unknown Source)
at org.hsqldb.StatementDML.delete(Unknown Source)
at org.hsqldb.StatementDML.executeDeleteStatement(Unknown Source)
at org.hsqldb.StatementDML.getResult(Unknown Source)
... 88 moreMADSONIC 5.2.5250.20141025.1033
Br
-m-
