Left Nav Errors
pcsteve
Left Nav Errors
Unread post by pcsteve »
After rebooting my 2012R2 box post MS updates I logged back into Madsonic and am now getting the following errors. It had been working fine prior to reboot. I have restarted the service logged in as admin but still the same errors. See attached error text and log file
madsonic.log
Log file
(23.92 KiB) Downloaded 546 times
Error.txt
errors from left Nav
(11.61 KiB) Downloaded 552 times
Magica
Re: Left Nav Errors
Unread post by Magica »
I get also left nav errors. One was caused by removing one folder in music folders.
I did some tests and I manage to focus the problem to Access rights.
None of my users are not in ALL-group so i disabled the Access rights on this group. Then left nav error start.
I enabled Access rights to group ALL Madsonic starts working normally.
I thing there is something wrong in Groups handling because you can´t name them differently from default naming or the groups cannot be deleted.
Deleting gives this error:
Exception	org.springframework.dao.DataIntegrityViolationException
Message	PreparedStatementCallback; SQL [delete from user_group where id=?]; integrity constraint violation: foreign key no action; FK_GROUP_ID table: USER; nested exception is java.sql.SQLIntegrityConstraintViolationException: integrity constraint violation: foreign key no action; FK_GROUP_ID table: USER
Java version	Oracle Corporation 1.8.0_25
Operating system	Windows 7 6.1
Server	Apache Tomcat/8.0.14
Memory	Used 632 of 742 MB
Stack trace	org.springframework.dao.DataIntegrityViolationException: PreparedStatementCallback; SQL [delete from user_group where id=?]; integrity constraint violation: foreign key no action; FK_GROUP_ID table: USER; nested exception is java.sql.SQLIntegrityConstraintViolationException: integrity constraint violation: foreign key no action; FK_GROUP_ID table: USER
	at org.madsonic.dao.AbstractDao.update(AbstractDao.java:71)
	at org.madsonic.dao.GroupDao.deleteGroup(GroupDao.java:70)
	at org.madsonic.service.SecurityService.deleteGroup(SecurityService.java:259)
	at org.madsonic.controller.GroupSettingsController.handleParameters(GroupSettingsController.java:87)
	at org.madsonic.controller.GroupSettingsController.handleRequestInternal(GroupSettingsController.java:47)
	at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:919)
	at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:851)
	at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:855)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:644)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:725)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:291)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
	at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:219)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:506)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:142)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
	at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:610)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:537)
	at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1081)
	at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:658)
	at org.apache.coyote.http11.Http11NioProtocol$Http11ConnectionHandler.process(Http11NioProtocol.java:222)
	at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1566)
	at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1523)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
Caused by: java.sql.SQLIntegrityConstraintViolationException: integrity constraint violation: foreign key no action; FK_GROUP_ID table: USER
	... 83 more
Caused by: org.hsqldb.HsqlException: integrity constraint violation: foreign key no action; FK_GROUP_ID table: USER
	at org.hsqldb.StatementDML.performReferentialActions(Unknown Source)
	at org.hsqldb.StatementDML.delete(Unknown Source)
	at org.hsqldb.StatementDML.executeDeleteStatement(Unknown Source)
	at org.hsqldb.StatementDML.getResult(Unknown Source)
	... 88 more
I´m running version:
MADSONIC 5.2.5250.20141025.1033
Apache Tomcat/8.0.14, java 1.8.0_25, Windows 7
Br
-m-
