I just registered and logged in via localhost:4040, and then I signed in temporarily with the 'admin' password.
After changing my password, I cannot get in anymore...?
I even clicked "forgot password", but it says the username does not exist
Just registered.. cannot login
laffytaffykidd
- Been thanked: 0
laffytaffykidd
- Been thanked: 0
Re: Just registered.. cannot login
I uninstalled and reinstalled many times, but when I go to localhost:4040, it doesn't give me the option to create/reset
laffytaffykidd
- Been thanked: 0
When I uninstalled, it says it is deleting C:\madsonic soooo I assumed that it was already being cleared out. I'm not by my computer right now, but I will double check to make sure the directory is gone when I hit uninstall
