Madsonic Server 5.0 Musicbee Plugin
Madsonic 5.x Musicbee Plugin
http://getmusicbee.com/
Contribution: http://musicbee.wikia.com/wiki/Subsonic_Client developed by Steven
Current release v1.0.0:
Madsonic Plugin (MB_MadSonic.dll)
INSTALLATION
- if you dont have a Plugins sub-folder where Musicbee is installed create one
- copy MB_MadSonic.dll to the Plugins sub-folder
- you should end up with something like: c:\program files\MusicBee\Plugins\MB_MadSonic.dll
- restart MB, and in the Plugin preferences enable Madsonic
- host is your server name without the http:// at the start
- port is the server port
- path is normally the default "\"
- username
- password
- transcode stream - only tick if you need to reduce the size of the file streamed from the server because the connection is slow
- on clicking Apply, MB will validate the settings - any errors are those as returned by Madsonic
If no error is reported on setup, a Madsonic drive will appear in the computer section. Clicking the parent node will show the entire library, but you can also view playlists and folders. It will take some time to initially load the main Madsonic node the very first time (several minutes to 30 minutes for very large libraries on slow connections). It should be quick from then on
You can reference the Madsonic drive from Auto-Playlists, the Auto-DJ or create manual playlists (but in all cases these reside in your MusicBee library, not on the Madsonic server). If you add files to your local MusicBee library, MB will keep track of playcounts and enable ratings to be stored (but only in the local MusicBee library cache, not on the server).
In the main panel, MusicBee will only show the tags that Madsonic makes available which are the basic ones you need (Artist, Title, Album, Track#, Year, Genre and Duration).
DOWNLOAD
plugin.musicbee.1.0.0.zip
(28.04 KiB) Downloaded 1503 times
Saklasklas222HeavensNight
Rating: 15.38%
Saklasklas222
Re: Madsonic Server 5.0 Musicbee plugin
Unread post by Saklasklas222 »
Nice! Are there any plans to make this plugin full compatible with madsonic api, so features like playlists, starred, queue in flash players will work with Musicbee? In other words...Musicbee become windows interface for Madsonic? That would be massacre!
HeavensNight
Has thanked: 4 times
Unread post by HeavensNight »
Thank you so much for this plugin :o
Edit: this not working in my server say damaged archive, this bug happend me before long time ago in subsonic, is because is someting in the folder structure dont like characters spaces or (),
you could add album artist support?
Thanks for you work.
HeavensNight
Re: Madsonic Server 5.0 Musicbee Plugin
i find a bug, if your sctructure have () like artist/(year) album/filename.ext. the plugin dont work.
you could please add album artist support? becuase is a mess without them.
greetings.
These users thanked the author HeavensNight for the post:
HeavensNight
HeavenNight wrote:i find a bug, if your sctructure have () like artist/(year) album/filename.ext. the plugin dont work.
greetings.
Update..
i did some test in my library. i found the bug of the last post only affect you if you using transcoding, (example FLAC To MP3) and other format besides mp3. if you no using some kind of transcoding, the plugin works but only if you select "transcode streams" in the plugin. (i dont have any kind of transcode active in server side)
but i found a bug, if you select the folder of the album don't show the songs,
only show the songs if you select from the root of the madsonic plugin (like the fisrt picture) or artist folder
Besides of that bugs, the plugin is working very well :D i use daily without any problem, just need add support for ssl servers and album artist and this become the perfect plugin / desktop madsonic player.
Thank you very much for you work.
Greetings.
Override92
Has thanked: 9 times
Unread post by Override92 »
Hi Everyone,
why does the plugin not support https?
Override92
troycarpenter
Has thanked: 28 times
Been thanked: 50 times
Override92 wrote:Hi Everyone,
Override92
Is this plugin still developed? My server is https as well and it didn't work
new Plugin for Madsonic 6.2 and MusicBee 3.0 is in development!
sparc
Has thanked: 7 times
Unread post by sparc »
Madevil wrote:hi there,
Any update on this? Just curious.
