It woul be nice, if I share a video to someone, that this one can then choose between the bitrate for transcoding as an guest/anonymous.
Or to setup a higher bitrate for the "share"-guest player as a default.
In the options i found the menu 'groups', where I can set the default bitrates, but this has no effect to the "share site's"-player.
Is there a solution to fix it or to manually fix this???
lolomm
EDIT: --> FYI
I have found a solution for set a static bitrate in the external player which is used for shared url:
C:\Program Files\Apache Software Foundation\Tomcat 7.0\webapps\<madsonic>\WEB-INF\jsp\
--> edit the externalplayer.jsp and add the folloging lines:
var maxBitRate = 5124;
// var maxBitRate = ${model.maxBitRate};Code: Select all
<script type="text/javascript">Code: Select all
file: "${streamUrl}",Code: Select all
file: "${streamUrl}${song.video ? "&maxBitRate=\" + maxBitRate" : "\""},
