aiff NOT being transcoded [SOLVED]
Posted: 08 Nov 2013, 08:56
by etyrnal
using most recent .deb build of Madsonic server running on Ubuntu 13.10,aiff files not being transcoded
Re: aiff NOT being transcoded [SOLVED]
Posted: 02 Dec 2013, 17:53
by etyrnal
in the Transcode setting, the default, newly installed settings said, Audioffmpeg, instead of ffmpeg
see attached images
based on ubuntu install using "sudo dpkg -i 20131130_madsonic-5.0.3800.deb"
i just manually removed the "Audio" from each instance of Audioffmpeg
Posted: 02 Dec 2013, 19:23
with build 3800 i changed something with transcoding.
There are new transcoding profils, but not activated as default.
Go to settings -> tab Reset. Here you can easaly switch
your transcoding profil.
With the deb and rpm package i must recheck the setup for new transcoding tools.
Maybe some installation refers ffmpeg, lame, xmp, flac, ... to wrong places
