Exclude Folders
tofuSCHNITZEL
- Been thanked: 1 time
Exclude Folders
is there a way to exclude certain (sub)folders from scanning like "$RECYCLE.BIN"?
tofuSCHNITZEL
Re: Exclude Folders
I have a whole harddisk on the index and because madsonic is running under Windows there is a $Recycle.bin folder.
tofuSCHNITZEL
Re: Exclude Folders
well of course this is a solution... but I wanted to suggest that it might be a good idea to have exclude folder/file option in the settings e.g. under the media folders tab...gurutech wrote:Make a subfolder at the root level (ie. S:\Madsonic) and put everything you want to share inside that folder. Then add that folder (not S:\) to the Media Library.
tofuSCHNITZEL
Re: Exclude Folders
if it works this would be a solution...Metzlmane wrote:i have all folder on drive M
and in M:\madsonic_exclude.txt
_artistpictures
_Playlists
___toSort
@Recycle
Is this what you want?
do I have to rescan media folders for it to be effective?
tofuSCHNITZEL
Re: Exclude Folders
Hm my madsonic_exclude.txt looks like this:
@Recycle
$RECYCLE.BIN
but after a Normal Rescan the folder is still visible in the list...
@Recycle
$RECYCLE.BIN
