Updating Build, How to Migrate "Welcome Message" Text?
Posted: 06 Oct 2013, 19:16
by lmike6453
I am migrating for 5.0 b3572 to 5.0 3740 and I wanted to know how to keep all of my settings. I am running Windows Server 2008 and copied over the "db" and "db.bakup" folders which transferred my users.
How can I copy over the "Welcome Message" text form the General tab?
Re: Updating Build, How to Migrate "Welcome Message" Text?
Posted: 06 Oct 2013, 20:02
by chali
why not just copy the text into a txt document and then paste it again?
/ Chali
Posted: 07 Oct 2013, 00:27
by lmike6453
chali wrote:Hi
/ Chali
Thanks for the response. I could have but I already upgraded and would have to clean reinstall old version just to copy the text.
Posted: 10 Oct 2013, 01:18
by BKKKPewsey
I believe that info is in the xxx.script file eg. subsonic.script or madsonic.script depending on version.
So you just to need to copy (and possibly rename) that file to your working directory.
Posted: 11 Oct 2013, 21:59
by lmike6453
BKKKPewsey wrote:I believe that info is in the xxx.script file eg. subsonic.script or madsonic.script depending on version.
Thanks for the response but no dice, didn't work. Copied it to c:\madsonic\db and also the one in c:\madsonic\db.backup
Posted: 17 Oct 2013, 19:26
this settings is saved into those files
build <3700 --> subsonic.properties
build >3700 --> madsonic.properties
