Updating Build, How to Migrate "Welcome Message" Text?
lmike6453
Has thanked: 3 times
Unread post by lmike6453 »
I am migrating for 5.0 b3572 to 5.0 3740 and I wanted to know how to keep all of my settings. I am running Windows Server 2008 and copied over the "db" and "db.bakup" folders which transferred my users.
How can I copy over the "Welcome Message" text form the General tab?
chali
Has thanked: 18 times
Been thanked: 35 times
Re: Updating Build, How to Migrate "Welcome Message" Text?
Unread post by chali »
why not just copy the text into a txt document and then paste it again?
/ Chali
lmike6453
chali wrote:Hi
/ Chali
Thanks for the response. I could have but I already upgraded and would have to clean reinstall old version just to copy the text.
BKKKPewsey
Has thanked: 4 times
Unread post by BKKKPewsey »
I believe that info is in the xxx.script file eg. subsonic.script or madsonic.script depending on version.
So you just to need to copy (and possibly rename) that file to your working directory.
:mrgreen:
lmike6453
BKKKPewsey wrote:I believe that info is in the xxx.script file eg. subsonic.script or madsonic.script depending on version.
:mrgreen:
Thanks for the response but no dice, didn't work. Copied it to c:\madsonic\db and also the one in c:\madsonic\db.backup
this settings is saved into those files
build <3700 --> subsonic.properties
build >3700 --> madsonic.properties
