Stream emmbedded subtitles
Re: Stream emmbedded subtitles
http://forum.madsonic.org/viewtopic.php?f=14&t=706
Pretty much out of luck
got i work with encoding mkv to mp4 and burnining subst to mp4.
chali
- Has thanked: 18 times
- Been thanked: 35 times
hi
if you use the app and mx player its no problem.
But there are some problems to turn off subtitles or switch to another language then the first in line. In other words,if you only have one sub, it should be ok.
/Chali
/Chali
