about FULL-SCAN
fumiman
Has thanked: 5 times
about FULL-SCAN
Unread post by fumiman »
hi guys. Konbanwa.
Im Japanese madsonic user :D
I need help.
I always launch normal scan after makes new sub-folder and add songs or move files.
but normal scanning cannot add songs on madsonic.
so, I launch FULL-SCAN 2 times.
at first in FULL SCAN failed to add songs.
second time FULL SCAN success to add songs.
but sometimes all stars disappear in my starred song. :(
so I started to star song from the beginning...
can anyone tell me about this things?
Server spec.
Windows 8 64bit 2GB
always using newest madsonic.
Re: about FULL-SCAN
i hope with last Beta5 Build your scan problems are gone.
fumiman
Re: about FULL-SCAN
thanks for replying. :D
I already use 5.0 3600 beta5.
finally , FULLscan almost fail to add songs.... :(
why...
which info should I tell u? >_<
tar
Re: about FULL-SCAN
Unread post by tar »
Hello
I had the same problem that "Scan media folders now" did not find any new music.
Then I found this thread:
--- forum.subsonic.org/forum/viewtopic.php?f=2&t=10397
and I quote this answer:
Re: Some folders not found
Postby GJ51 » Tue Oct 09, 2012 2:28 am
Go to settings
Uncheck any directories in "Media Folders" that have folders or files that are not showing.
Save
Click on Clean-up database
Scan media folders
Recheck all folders
Save
Rescan
Enjoy music :)
I did these steps, and madsonic now can play my new music!
hope this helps...
My specs are:
Ubuntu 12.04 32 bit
Oracle java jdk1.7.0_40
Tomcat 7
Madsonic Server 5.0 Build 3780, WAR install
