Android Client 5.4
Amazon App Store Link
Release Note
General
- BS Videoplayer support
- VLC Videoplayer support
- Dialog: add song to new created Playlist
- small Bugfixes
hi there,chali wrote:Hello and thank you for all your work =)
in this vertion has blitvit problems to stream,
movie starts not until the entire film is transferred;
Now, I have not had time to test if it's the app or if it is the server vertionen that is the problem for me. (I use beta4 3560 Debian)
does anyone have an idea what could be the problem?
last vertionen worked perfeckt for me with mx player.
and vertionen 3550 Debian)
/ Sincerely Chali
Madevil wrote:hi there,chali wrote:Hello and thank you for all your work =)
/ Sincerely Chali
whats is a blitvit ???
Maybe the newer ffmpeg version have problems with some video transcodings,
did you try the last or older ffmpeg version?
higurutech wrote:Just downloaded this version, after sticking with 5.0 since that came out. Reason for the upgrade was because I keep getting "server cannot be found" error messages, and a timeout after 4 attempts.
I figured it was due to the server itself, being upgraded from 35xx up to 3700, which was just released. Since Ultrasonic was giving the same error, I didn't think it was an app issue, however I thought maybe the server was responding to the connection request in a new
Well, the upgrade didn't fix the problem.
Any idea what could be causing this issue?
higurutech wrote:very strange.... I plug in my actual IP address, with port 4040, and it works.
Not sure why the domain name I'm using isn't working, but I'm gonna have to look into that.... Everything seems to be working fine when I go over a browser....
hmm starting to get low on idesgurutech wrote:It's all the time, but only when using my DNS name. Using No-IP.com on a port 80 redirect (to get around my ISP blocking port 80).
Works fine if I use my external IP address and put in port 4040.
Works fine using IP address or DNS name from a browser.
it don't work for me neither.commonplace wrote:I can't seem to get the Madsonic app to send Bluetooth information to my car's stereo. It works on Google Play Music and others, but not Madsonic... am I doing something wrong, or is this not supported??
ramapoughnative wrote:Greetings.. Minor issue. I'm using android app 5.4 and even though it's paid for, still getting commercial splashscreen on pause.. why? BTW.. thank you for writing and sharing this app..
truly enjoy it..
