Starred track in subsonic -> Loved track in last.fm
Posted: 08 Jul 2013, 05:00
by Quantumcross
Is there a way in the last.fm api to make it so that all starred tracks in subsonic become "loved" tracks within last.fm?
Re: Starred track in subsonic -> Loved track in last.fm
Posted: 08 Jul 2013, 21:05
Quantumcross wrote:Is there a way in the last.fm api to make it so that all starred tracks in subsonic become "loved" tracks within last.fm?
the API should can do that, but i must integrate it first into the Madsonic db schema.
I put this on the todo list.
Posted: 09 Jul 2013, 04:13
by Quantumcross
Thanks for looking into it! I appreciate it!
Posted: 25 Jul 2013, 08:53
by pa2k
Probably redundant comment, but hey: this should be a toggle in settings as there may be differing uses of the two.
Posted: 22 Dec 2013, 01:19
by wikke
sorry to bump this.
But I'm looking for a way to sync my Last.FM loved tracks with Madsonic starred tracks (both ways, or last.fm -> madsonic).
I believe this is not yet implemented, correct?
Would this also be a part of this feature request or should I make a new topic ?
Does anyone know a workaround until it's implemented?
Posted: 23 Dec 2013, 08:04
by HeavensNight
+1
Posted: 23 Dec 2013, 12:56
by wikke
I looked into a workaround yesterday.
I managed to automate the download of the loved tracks to an xspf playlist. As you may know, the last.fm playlist purely contains the track metadata.
Unfortunately subsonic is incapable to play xspf playlists based on metadata (location based probably works though...). So I'm still stuck...
Sent from my Nexus 4
Posted: 27 Apr 2016, 14:37
by rolle
Loved tracks sync (and other data sync like genres) are implemented in Musiccabinet and I loved it for that. Would love to see the same thing in Madsonic.
