Starred track in subsonic -> Loved track in last.fm
Quantumcross
- Been thanked: 0
Is there a way in the last.fm api to make it so that all starred tracks in subsonic become "loved" tracks within last.fm?
Re: Starred track in subsonic -> Loved track in last.fm
hi there,Quantumcross wrote:Is there a way in the last.fm api to make it so that all starred tracks in subsonic become "loved" tracks within last.fm?
the API should can do that, but i must integrate it first into the Madsonic db schema.
I put this on the todo list.
Quantumcross
- Been thanked: 0
Thanks for looking into it! I appreciate it!
sorry to bump this.
But I'm looking for a way to sync my Last.FM loved tracks with Madsonic starred tracks (both ways, or last.fm -> madsonic).
I believe this is not yet implemented, correct?
Would this also be a part of this feature request or should I make a new topic ?
Does anyone know a workaround until it's implemented?
HeavensNight
- Has thanked: 4 times
- Been thanked: 7 times
I looked into a workaround yesterday.
I managed to automate the download of the loved tracks to an xspf playlist. As you may know, the last.fm playlist purely contains the track metadata.
Unfortunately subsonic is incapable to play xspf playlists based on metadata (location based probably works though...). So I'm still stuck...
Sent from my Nexus 4
Loved tracks sync (and other data sync like genres) are implemented in Musiccabinet and I loved it for that. Would love to see the same thing in Madsonic.
