Synology - tomcat
hanshans
Has thanked: 5 times
Synology - tomcat
Unread post by hanshans »
Someone who knows how to get madsonic working on tomcat on my synology nas ?
Re: Synology - tomcat
hanshans wrote:Someone who knows how to get madsonic working on tomcat on my synology nas ?
Do you know Erics blog about synology and subsonic/madsonic http://www.eg-blog.de :!:
He make a realy good port from an older 4.8 version
Infos: http://www.eg-blog.de/?cat=8
Download: http://www.eg-blog.de/?cat=10
hanshans
yes i also found another guide.
But it would really be nice to get it working in tomcat. Is it because of java it does not work or whats the problem ?
GJ51
Has thanked: 42 times
Been thanked: 83 times
Unread post by GJ51 »
I run all my Madsonic sites on Tomcat, but on Windows platforms with the latest Java release.
I don't use Linux much, but my experiences in this forum and the Subsonic forum lead me to believe that Linux setup is more complicated and more difficult. I'm sure a seasoned Linux user would say the same thing about Windows, but it does seem that more Linux users run into difficult setup and installation issues.
As for running any Mad/Sub Sonic on a NAS, you are likely to run into issues that aren't seen elsewhere.
I know Gururtech runs Linux and has assisted many others with their installation issues. Perhaps a PM to him might get you some specific tips with your particular problem.
HTH
Has thanked: 11 times
Been thanked: 105 times
Unread post by gurutech »
Not sure how to get Madsonic on a Synology NAS (or any NAS for that matter, although as soon as I can afford one, I'm sure I'd at least try to get it working!)
I do use Linux, but I'm using Apache, and not Tomcat. From what I understand, to use Tomcat, you need to extract or download only the .WAR file and place it in a certain location on your device. There's threads over on the Subsonic Forum that may help.
GJ51
Tomcat is a pretty easy install on windows. Install Java, install Tomcat, don't run the service immediately after the installation. delete the default work subdirectory -C:\Program Files\Apache Software Foundation\Tomcat 7.0\work - then drop the .war file into C:\Program Files\Apache Software Foundation\Tomcat 7.0\webapps.
Now your almost ready. If you are going to be accessing files that will need user permissions, such as a network share, then you have to edit the Tomcat service to use a logon with the proper permissions. Start the service and it automatically deploys the war and sets up the proper directories and everything is ready to go.
I don't know how much different it is in the Linux world, but it's pretty simple on Windows. It seems a bit faster than the Windows installer version and has the benefit of being a bit easier to upgrade as all you have to do is stop the Tomcat service, delete the work directory and the webapps\Subsonic directory, drop in the new war file and restart the service. Only takes a couple minutes once you get used to the sequence.
hanshans
It should be pretty easy. But this is what i get from the log
SEVERE: Error deploying web application archive subsonic.war
java.lang.UnsupportedClassVersionError: net/sourceforge/subsonic/filter/BootstrapVerificationFilter : Unsupported major.minor version 51.0 (unable to load class net.sourceforge.subsonic.filter.BootstrapVerificationFilter)
        at org.apache.catalina.loader.WebappClassLoader.findClassInternal(WebappClassLoader.java:2858)
        at org.apache.catalina.loader.WebappClassLoader.findClass(WebappClassLoader.java:1159)
        at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1647)
        at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1526)
        at org.apache.catalina.startup.WebAnnotationSet.loadClassAnnotation(WebAnnotationSet.java:145)
        at org.apache.catalina.startup.WebAnnotationSet.loadApplicationFilterAnnotations(WebAnnotationSet.java:84)
        at org.apache.catalina.startup.WebAnnotationSet.loadApplicationAnnotations(WebAnnotationSet.java:57)
        at org.apache.catalina.startup.ContextConfig.applicationAnnotationsConfig(ContextConfig.java:297)
        at org.apache.catalina.startup.ContextConfig.start(ContextConfig.java:1078)
        at org.apache.catalina.startup.ContextConfig.lifecycleEvent(ContextConfig.java:261)
        at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:142)
        at org.apache.catalina.core.StandardContext.start(StandardContext.java:4612)
        at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:799)
        at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:779)
        at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:601)
        at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:943)
        at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:563)
        at org.apache.catalina.startup.HostConfig.check(HostConfig.java:1399)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
        at java.lang.reflect.Method.invoke(Method.java:597)
        at org.apache.tomcat.util.modeler.BaseModelMBean.invoke(BaseModelMBean.java:297)
        at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.invoke(DefaultMBeanServerInterceptor.java:836)
        at com.sun.jmx.mbeanserver.JmxMBeanServer.invoke(JmxMBeanServer.java:762)
        at org.apache.catalina.manager.ManagerServlet.check(ManagerServlet.java:1500)
        at org.apache.catalina.manager.HTMLManagerServlet.doPost(HTMLManagerServlet.java:252)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
        at org.apache.catalina.filters.CsrfPreventionFilter.doFilter(CsrfPreventionFilter.java:194)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
        at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
        at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
        at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:563)
        at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
        at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
        at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
        at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
        at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:861)
        at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:606)
        at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
        at java.lang.Thread.run(Thread.java:662)
- catalina.2013-07-07.log 114/114 100%
if i try to access the site i get
HTTP Status 503 - This application is not currently available
type Status report
message This application is not currently available
description The requested service is not currently available.
Apache Tomcat/6.0.36
hanshans wrote:It should be pretty easy. But this is what i get from the log
type Status report
This mean you have an older JAVA Version then 7, you should upgrade your installation.
Madsonic works on tomcat but also need java 7.
GJ51
GJ51 wrote:I run all my Madsonic sites on Tomcat, but on Windows platforms with the latest Java release.
HTH
I only repost to point out how difficult it can be to identify the source of a problem when a user looking for help discounts the details given in a post. Although there are differences in the OS, it is helpful to eliminate as many variables as possible to get to the problem source. Differences in Java versions, Tomcat versions, and countless other variables can easily cause problems that will be hard to pinpoint if a user looking for assistance overlooks the implications of the contents of a post. Throw in transcoding strings and differences ffmpeg versions and figuring out the source of a given problem can get very hard to pinpoint.
hanshans
damn. Dont think java 7.0 is supported in ds412+ :-(
Think i have to start using my normal server again.
If someone know a workaround i would love to know
hanshans wrote:damn. Dont think java 7.0 is supported in ds412+ :-(
with final madsonic 5.0 i also build a Java 6 backwards compatibility version.
hanshans
hanshans
Nice :-D.
When do you think it would be ready. And whats the diffence running madsonic in java 6 or 7 ?.
