OK - I've been working on testing HTML 5 playback on 5.0.3510.beta3 for a while and keep running into some issues. Everything works fine with the flash setup, but like others, I'd like to see if I can get the HTML5 setup working for forward compatibility.
Everything seems to be in order but video playback halts every few seconds even on lower resolution video and task manager shows that CPU loads are not an issue. Same videos under the flash setup run smooth without any buffering. The videos run for 2-3 seconds then freeze for 10-20 seconds and then repeat that cycle.
Version 5.0.3510.beta3
Server Apache Tomcat/7.0.39, java 1.7.0_21, Windows Server 2008 R2 (96.0 MB / 178.4 MB)
EDIT: I've noticed that when you hover on the JW Player bar it shows on the right "Infinity:NaN:NaN" which makes me think that maybe the player or ffmpeg is not getting a reading on the track length and the process may be stopping and starting because it can't tell where the end of the file is?? I've tested both versions of JW 6.10 - both exhibit the same behavior. Any video at 1280x720 or higher has problems, lower resolution videos up to 6408x480 are OK.
HDTV Playback on HTML5 stops frequently
Re: HDTV Playback on HTML5 stops frequently
Maybe I have the same problem but still no solution:
http://forum.madsonic.org/viewtopic.php?f=14&t=593 (How to use MX Player)
I'm still investigating the problems I've been having, but it just may be that it's all related to a drive that just went bad on my storage server. I replaced the drive and will do some more testing soon.
No joy. I did a clean install of original old fashioned Subsonic and set the media folder to the recorded TV up on my HTPC which is a different library from my archive on my storage server. Same problem. Video is blurry and clearly NOT the HDTV quality originally recorded and that plays just fine through WMC.
Therefore, something has changed somewhere that I still can't identify. It's either the latest version of Java or ffmpeg or something else I haven't thought of yet. Either way this is not good and I'm a bit frustrated after several weeks of testing and I still can't get any version on any of my servers to read HDTC properly after having had this work well for a couple years.
I'm a bit surprised that there aren't more reports of this happening.
Whatever is causing the problem the one consistent problem is that the resolution is being misread. I have folders with series episodes that report some episodes correctly at 1920X1080 and play fine yet other episodes report as 200X113 and look like that when played back. Why some are reported and play correctly and others don't is anyone's guess. It's not only wtv files but I see the same problem with other video formats whenever resolution exceeds 6480X480. I put a screen capture below so you can see the problem. All recordings shoe they were recorded at more than 15000kbps, but half read as 1920X1080 and the rest read 200X113.
None of it makes any sense to me. I've been using Subsonic to playback video since before it was made a part of Subsonic as a standard feature and never saw this before. Oh well, it's still great for music.
Firefly 10th Anniversary- Browncoats... 1:02:51 16482 Kbps (200x113)
Firefly_SCIHD_2012_11_11_06_58_00 2:01:47 16388 Kbps (200x113)
Firefly_SCIHD_2012_11_11_08_58_00 1:01:56 16257 Kbps (1920x1080)
Firefly_SCIHD_2012_11_11_09_00_05 59:48 16508 Kbps (200x113)
Firefly_SCIHD_2012_11_11_10_00_00 59:55 16239 Kbps (200x113)
Firefly_SCIHD_2012_11_11_11_00_00 59:56 16699 Kbps (1920x1080)
Firefly_SCIHD_2012_11_11_11_00_02 59:52 16743 Kbps (1920x1080)
Firefly_SCIHD_2012_11_11_12_00_00 59:55 16319 Kbps (200x113)
Firefly_SCIHD_2012_11_11_13_00_00 30:55 16638 Kbps (1920x1080)
Firefly_SCIHD_2012_11_11_14_00_00 59:57 16433 Kbps (1920x1080)
Firefly_SCIHD_2012_11_11_15_00_00 59:56 16171 Kbps (1920x1080)
Firefly_SCIHD_2012_11_11_15_58_00 1:01:56 16391 Kbps (200x113)
Firefly_SCIHD_2012_11_11_17_00_00 59:55 16463 Kbps (1920x1080)
Firefly_SCIHD_2012_11_11_17_00_01 59:47 16474 Kbps (1920x1080)
Firefly_SCIHD_2012_11_11_18_00_00 59:57 16395 Kbps (1920x1080)
Firefly_SCIHD_2012_11_11_18_00_02 59:54 16486 Kbps (1920x1080)
Firefly_SCIHD_2012_11_11_19_00_00 59:55 16597 Kbps (200x113)
Firefly_SCIHD_2012_11_11_20_00_00 59:55 16713 Kbps (1920x1080)
Firefly_SCIHD_2012_11_11_20_00_02 59:47 16725 Kbps (1920x1080)
Firefly_SCIHD_2012_11_11_21_00_00 1:02:55 16328 Kbps (200x113)
Firefly_SCIHD_2012_12_24_06_58_00 2:04:55 16382 Kbps (200x113)
Firefly_SCIHD_2012_12_24_12_58_00 1:01:57 16379 Kbps (200x113)
Firefly_SCIHD_2012_12_24_14_00_00 59:56 16657 Kbps (200x113)
Firefly_SCIHD_2012_12_24_15_00_01 1:02:54 16437 Kbps (200x113)
Firefly_SCIHD_2013_05_19_08_58_00 1:01:55 15754 Kbps (200x113)
Firefly_SCIHD_2013_05_19_10_00_01 59:55 15820 Kbps (200x113)
Firefly_SCIHD_2013_05_19_11_00_01 59:54 16253 Kbps (200x113)
Firefly_SCIHD_2013_05_19_12_00_01 1:02:55 16331 Kbps (200x113)
Firefly_SCIHD_2013_05_19_15_58_00 1:01:55 16325 Kbps (200x113)
Firefly_SCIHD_2013_05_19_17_00_01 59:51 16136 Kbps (200x113)
Firefly_SCIHD_2013_05_19_18_00_01 59:54 16277 Kbps (200x113)
Firefly_SCIHD_2013_05_19_19_00_01 59:54 16208 Kbps (200x113)
Firefly_SCIHD_2013_05_19_20_00_01 59:50 16192 Kbps (200x113)
Firefly_SCIHD_2013_05_19_21_00_01 1:02:54 15778 Kbps (200x113)
