Bookmark feature
Has thanked: 11 times
Been thanked: 105 times
Bookmark feature
Unread post by gurutech »
I listen to a lot of audiobooks, and was wondering how possible it would be to be able to set a bookmark or something, so I can come back to the same spot on a playlist if I log out and log back into Madsonic.
Also, would it be possible to set the bookmark on the desktop version, and then resume the playlist on a mobile device (iphone/android)? This way I could listen while at work, then continue where I left of while I'm on my way home...
Re: Bookmark feature
you will be surprised, this is already implemented (REST API) in the last Madsonic Build (5.0.3460) but its not in the interface.
This will work for each media-type (audio, video), each user can set bookmark separately.
So stay tuned until it comes to the Webinterface and Android-App. :D
