Hi Madsonic,
in Settings Icons you can enable or disbale menue-icons for users.
If I disable "Mood" it is still visible for users.
There is no icon "About" to be seen but in the settings you can enable and disable it.
You can reach "About" if you click on the Madsonic-Icon in the upper left corner.
The About-Page is shown in any way if you enable or disable "About."
4.8 Build 3390: Settings - Icons
Re: 4.8 Build 3390: Settings - Icons
This is fixed in the coming 5.0 Branch.
