Moods & Genre Not Available
magikbus
Unread post by magikbus »
I have installed Madsonic V 4.8.3320.beta3 and I am unable to select the Genre and Moods Icon options in the settings section. Is there something else I need to turn on of install to get that functionality working?
Re: Moods & Genre Not Available
Hi, in this version the option are only placeholders.
To enable moods you must upgrade to the newest Build,
But genre ist at the moment not implemented.
magikbus
Okay I upgraded to version 4.8.3340.beta3 and I now see the Moods icon, but when clicked it only says please scan your library before. I have run the scan already, but it still says that. Does it take a day or so to compile?
Has thanked: 11 times
Been thanked: 105 times
Unread post by gurutech »
Newest build is 3350, but the same thing happens with that build as well. It appears that Moods will be something added in a later build.
