add playlist
Mission accomplished!
jonnymnemo
Has thanked: 3 times
Been thanked: 6 times
add playlist
Unread post by jonnymnemo »
Hi MadEvil !
I miss the option to add an entire playlist to the queue.
Would it be possible to put it back ?
Thanks !
Re: add playlist
Do you mean to ADD an existing Playlist to an already filled Play-queue (merge) ?
jonnymnemo
Re: add playlist
Yes, you said it better than me ! ;)
jonnymnemo
Re: add playlist
Hi !
Any news for this feature ?
Re: add playlist
i check this and its no problem, come hopefully with next release.
