Some of you probably know Clementine Player.
They have added subsonic support in their latest beta !
Hope it will soon become a stable release !
http://code.google.com/p/clementine-pla ... il?id=1930
[External player] Clementine player and subsonic
jonnymnemo
- Has thanked: 3 times
- Been thanked: 6 times
- These users thanked the author jonnymnemo for the post:
- admin
jonnymnemo
Re: [External player] Clementine player and subsonic
If you want to try it, the dev version is here :
http://builds.clementine-player.org/win32/release/
It doesn't work for me, I suppose because of a ssl problem.
wow, great player
SSL worked for me .. -> try https:// .... instead of http://... if you enabled SSL
jonnymnemo
I finally managed to make it work (using https:/xxx.xxx.xxx.xxx:port/), but the search engine for subsonic is not always accurate. But great player indeed !
