Can I change the way madsonic saves coverart... I don't use cover.jpg in my setup only folder.jpg... but anytime I change album art it always saves to cover.jpg....
thanks for the great mod btw!!
Coverart file name option
Re: Coverart file name option
Hi, yes i can make a option for this because its as default hardcoded.
- troycarpenter
- Has thanked: 28 times
- Been thanked: 50 times
Old thread alert....
Did this ever happen? I thought I saw this option once, but I can't find it again. On Android, the media scanner seems to ignore cover art with the name "AllbumArt.jpg". Right now my photo gallery is full album art. I don't want to use the ".nomedia" option since I use the MP3s for other notifications and such.
Dear Madevil,Madevil wrote:Hi there,
will be fixed with next release.
+1 for customizable cover file name
And *please* also add an option to keep downloaded cover art jpegs inside madsonic installation folder, for instance, in c:\madsonic\covers. In that case simple cover.jpg/folder.jpg won't work, so the simplest solution would be using album ID from media_file table as file name + jpg extension.
Thanks beforehand
