Automatic update [Done]
Mission accomplished!
jonnymnemo
Has thanked: 3 times
Been thanked: 6 times
Unread post by jonnymnemo »
Hi MadEvil !
Now that you host yourself your download files, maybe it would be possible to set an automatic update feature.
What do you think ?
Re: Automatic update
hi,
this is a good idea ;)
will come with the next builds
jonnymnemo
Thanks for the reply !
I think also of an automated script on linux, who would stop and update subsonic at a specific time if an update is available. Something like the one for updating madsonic.
For security reasons, the install part cannot be directly inside madsonic (especially when you use it in non root).
I will wait for your next builds to see what I can do with this part.
boco
Been thanked: 13 times
Re: Automatic update [Done]
Unread post by boco »
Strange - the auto update link shows a new version of 4.8.3336 but no new version is present?
I am running version 4.8.3330.beta3
Included is a screen shot
Don't know if a new version has just not been posted or the version check isn't working
boco
GJ51
Has thanked: 42 times
Been thanked: 83 times
Unread post by GJ51 »
I see the same thing. I just assumed that this is monitoring wherever he has his latest build stored. It probably needs to be changed bu ME to monitor the upload location rather than wherever he's compiling his latest build.
It is beta ... I'm sure he'll get it fixed.
sorry, i trigger this to early before i release the files to FTP Server. ;)
DoCC
Has thanked: 40 times
Been thanked: 65 times
Unread post by DoCC »
any updates mate ?
