When will the Android app be available on google play store
Eddie
Unread post by Eddie »
Any idea when this will be available
I have paid for Madsonic pro app and reset my phone and now i cant use madsonic since it was removed from the google play store.
These users thanked the author Eddie for the post:
Answers: 4
Has thanked: 1171 times
Been thanked: 457 times
Re: When will new app be available
The improved Android app will be released in the next few weeks. Development and tests are already at high gear.
Image Image Image Image Image Image Image Image
These users thanked the author Madsonic for the post (total 3):
kmil992000daemon9thfumiman
Rating: 23.08%
daemon9th
Unread post by daemon9th »
Excellent with a new client release, looking forward to it!
Are there any improvements to the Android Auto integration?
Eddie
Thank you for the update i guess ill sit tight and wait...
btw nice to see you are back
yougotborked
Unread post by yougotborked »
I would also very much appreciate better android auto integration!
These users thanked the author yougotborked for the post (total 2):
MadsonicChatNoir
Rating: 15.38%
Eddie
Re: When will the Android app be available on google play store
any update on the new version...
i personally do not care when you release the next version but for some reason you decided to remove the old app from the app store and i since i have a new phone i have no way of installing any madsonic app.... any updates at all?
Eddie
any update?
christophe Mallet
Unread post by christophe Mallet »
Hello
I have changed phones for some time and can not find the madsonic version for android, or can I find a link to reinstall it?
thank you for the answer
Chris
Eddie
Yup same with me... It's okay you take your time and work as long as you want on the new version of the app but why take the perfectly working version off of Google if you don't have a replacement ready?
kmil992000
Has thanked: 10 times
Unread post by kmil992000 »
Madsonic wrote:
26 Apr 2019, 15:01
Hi Madsonic Team,
Any update? Nearly 3 months since your last update now and still no sign of the new client app.
I paid for a subscription that included 2 licences for the client, yet I've never been able to redeem them as the app was removed from Google Play before I got a chance to download it, so I'm feeling a little short-changed here.
If the client is still not ready for full Google Play release, is there any chance of an alpha or beta apk version we can side-load to help with testing in the meantime? The screenshots look great btw and I'm looking forward to it being even better than DSub that I'm having to use instead at the moment. :D
Kev
Catsrules
Unread post by Catsrules »
Is there an update on this? I just got a new phone and I need to download the app again.
I would love to get a beta version of the new 7.x app but I can't even find the old version on the play store anymore.
What exactly am I suppose to do? I guess I could look at side loading the old version from some third party site but that isn't a very good solution.
What are my options for officially getting an apk?
These users thanked the author Catsrules for the post:
ombra040683
jlalanda
Unread post by jlalanda »
I need some help....
What client can i use for the android?
I have tested a lot of programs and no works...
Also i wanted to have the capacity to use offline mode and download to my mobile phone musics or albums that i choose.
Can you help me
fumiman
Has thanked: 5 times
Unread post by fumiman »
jlalanda wrote:
22 May 2020, 14:15
Can you help me
did u try madsonic app?
https://play.google.com/store/apps/details?id=github.madmarty.madsonic
