Unable to add Madsonic as a service in Sonos
Madsonic Server 6.x
renaemyers
Unread post by renaemyers » 10 Jan 2018, 18:31
I have tried to add Madsonic as as service in Sonos using both versions 6.2.9040 and 6.2.9080, after enabling Sonos as a music service in Settings, and in both cases Madsonic does not show up as an available service under Add Music Services in Sonos. My Sonos is version 8.2.2. Follows are the relevant log entries.
[1/10/18 6:46 AM]	INFO	SonosService	Found Sonos controllers: [10.0.0.151, 10.0.0.90]
[1/10/18 6:46 AM]	INFO	SonosServiceRegistration	Enabling Sonos music service, using Sonos controller IP 10.0.0.151, SID 244, and Madsonic URL http://10.0.0.140:4040/ws/Sonos
[1/10/18 6:46 AM]	WARN	SonosService	Failed to enable/disable music service in Sonos controller 10.0.0.151: org.apache.http.client.HttpResponseException: Bad Request
[1/10/18 6:46 AM]	INFO	SonosServiceRegistration	Enabling Sonos music service, using Sonos controller IP 10.0.0.90, SID 244, and Madsonic URL http://10.0.0.140:4040/ws/Sonos
[1/10/18 6:46 AM]	WARN	SonosService	Failed to enable/disable music service in Sonos controller 10.0.0.90: org.apache.http.client.HttpResponseException: Method Not Allowed
[1/10/18 6:46 AM]	INFO	NetworkService	Successfully forwarding port 4040.
Thank you.
Has thanked: 1153 times
Been thanked: 450 times
Re: Unable to add Madsonic as a service in Sonos
Unread post by Madsonic » 10 Jan 2018, 23:55
The older Madsonic version have problems with the newest SONOS 8.x Firmware,
please retry connectivity with the latest Madsonic version 6.3
renaemyers
Unread post by renaemyers » 11 Jan 2018, 01:10
Thank you for sending me a license key so I was able to download 6.3. After installing 6.3, I was successful in adding Madsonic as a music service in Sonos. Thanks again!
These users thanked the author renaemyers for the post:
Gartenlampe
Unread post by Gartenlampe » 04 Apr 2018, 21:46
I have also too this Problem is it probable for testing to become a test key ?
regards kurt
Madevil wrote:Hi there,
These users thanked the author Gartenlampe for the post:
Gartenlampe
Unread post by Gartenlampe » 05 Apr 2018, 06:40
Hello
With Sonos i have the same Problem too, is it probable to became i Test-Key for 6.3 Version
Regards kurt
Unread post by Madsonic » 18 Apr 2018, 10:04
To help please submit more information about your environment: http://forum.madsonic.org/viewtopic.php?f=65&t=1520
