i'm new to Madsonic and ... overwhelmed of this great peace of stoftware
Maybe I made a mistake during configuration because my Serverlog is flooded by messages of ERROR NowPlayingService
Error says:
Unexpected error in getNowPlaying: java.lang.SecurityException: Access denied to file /media/con2/video/[NAME_OF_THE_FILES]
What i did before was a Folder creation of /media/con2/video ...
Later i suggested to switch to /media/con2/video/##MOVIES/.... and /media/con2/video/##FAMILY/... e.g.
Totaly right that the path mentioned in the Error log isn't present any longer. But how to get rid of the messages?
What did i do to rescan all files ...
Full Rescan - Full Rescan easy trick
go to Media folder Settings
Disable each Music folder (this switch the entrys to Offline)
Save Settings
Make a Full Mediascan
Re-enable each Music folder to rescan
Save Settings
No success ... Errors resist.
I'm not sure where to delete any DB Entries of previous settings / path settings
Any Ideas?
I'm using Version 6.2.9040
Thank you for helping me
