So i have multi genre in my app, that means i need to be able to apply all calls genre specific
For example for the charts i need the top tracks (which is available) but for a specific genre
Latest added, trending...etc
For tracks, albums and artists
Sent from my iPhone using Tapatalk
Expand genre api
Re: Expand genre api
Dear Ahmed,a7medo778 wrote:Hi,
We put your suggestion to the todo list!
Please look at the API documentation, some REST calls already exist where you can specify your genre.
getArtistsByGenre http://beta.madsonic.org/pages/api.jsp# ... stsByGenre
getRandomAlbumsID3 http://beta.madsonic.org/pages/api.jsp# ... mAlbumsID3
getAlbumListID3 http://beta.madsonic.org/pages/api.jsp#getAlbumListID3
getRandomSongs http://beta.madsonic.org/pages/api.jsp#getRandomSongs
Thanks for the reply, its awesome that its added to the list as its import to create a proper charts featureMadevil wrote:Dear Ahmed,a7medo778 wrote:Hi,
If i may add, a time scope parameter (top played by week, month, all time) if possible
(Though i think it should be calculated once a day or a week)
- These users thanked the author a7medo778 for the post (total 2):
- Madsonic • Matt Zornig
- Rating: 15.38%
I like this, although its possible to get this information outside of madsonic, if you have configured the last.fm scrobbling in madsonic. Then you can just use the last.fm service (but I know, this is not what you want).a7medo778 wrote:If i may add, a time scope parameter (top played by week, month, all time) if possible
