Madsonic 6.2 on Synology
http://www.synology.com
for DSM 6.1.x only!
- Perl
- Java Manager 8
- prepare Synology hardware
- update to latest Synology DSM 6.1.x
- create new Volume
- create shared folder: Public
- activate user home service
- select installation from all publisher
- install Perl module
- install JavaManager module
- download latest Java JDK 8
- upgrade Java JDK on DSM
- cleanup old Madsonic installations
- reboot Synology
- install Madsonic 6.2 package
- set read/write access to share/volume for Madsonic
- start Madsonic service
- logon as admin user
- set system output to debug
- recheck and config your media, podcast and playlist paths
- config transcode path if missing
- set the Madsonic scanmode to MIXED if you have special file formats (example: aac, aiff, dff, dsf, opus, ogg, flac)
- make a full scan before you try searching or connection from clients
- check Madsonic log files
test package in preparation ...
- DSM Docker
- create new Volume for Docker
- install Docker module
- install Madsonic docker image madsonic/ubuntu-madsonic-beta
- set read/write access to /config and /media
- configure and start Madsonic docker container
- Java Manager 7
- Tomcat 7
- install Tomcat7 module
- download latest Java JDK 7
- config tomcat user and roles
- connect with SSH or WinSCP to your Synology
- mkdir /var/madsonic
- chown -R http:http /var/madsonic
- reboot Synology
- install Madsonic tomcat war
- start Tomcat service
