Madsonic fails to play next track in que
magicd2
Post by magicd2 »
Hi i have a recurring issue with madsonic where it fails to load the next track and has to be quit and restarted in order to have it work again. Sometimes this barely happens other times it is every track. this is the message i get once quitting Madsonic
Thanks in advance
Exception 	org.springframework.jdbc.CannotGetJdbcConnectionException
Message 	Could not get JDBC Connection; nested exception is java.sql.SQLException: Database lock acquisition failure: attempt to connect while db opening /closing
Java version 	Oracle Corporation 1.7.0_79
Operating system 	Mac OS X 10.11.4
Server 	jetty/8.y.z-SNAPSHOT
Memory 	Used 149 of 260 MB
Stack trace 	org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: Database lock acquisition failure: attempt to connect while db opening /closing
	at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:80)
	at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:575)
	at org.madsonic.dao.AbstractDao.query(AbstractDao.java:109)
	at org.madsonic.dao.AbstractDao.queryOne(AbstractDao.java:183)
	at org.madsonic.dao.UserDao.getUserSettings(UserDao.java:209)
	at org.madsonic.service.SettingsService.getUserSettings(SettingsService.java:2565)
	at org.madsonic.i18n.MadsonicLocaleResolver.doResolveLocale(MadsonicLocaleResolver.java:66)
	at org.madsonic.i18n.MadsonicLocaleResolver.resolveLocale(MadsonicLocaleResolver.java:54)
	at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1190)
	at org.springframework.web.servlet.DispatcherServlet.processDispatchResult(DispatcherServlet.java:1001)
	at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:945)
	at org.madsonic.filter.ResponseHeaderFilter.doFilter(ResponseHeaderFilter.java:49)
Caused by: java.sql.SQLException: Database lock acquisition failure: attempt to connect while db opening /closing
	at org.hsqldb.jdbc.JDBCConnection.(Unknown Source)
	at org.hsqldb.jdbc.JDBCDriver.getConnection(Unknown Source)
	at org.hsqldb.jdbc.JDBCDriver.connect(Unknown Source)
	at java.sql.DriverManager.getConnection(DriverManager.java:571)
	at java.sql.DriverManager.getConnection(DriverManager.java:187)
	at org.springframework.jdbc.datasource.DriverManagerDataSource.getConnectionFromDriverManager(DriverManagerDataSource.java:173)
	at org.springframework.jdbc.datasource.DriverManagerDataSource.getConnectionFromDriver(DriverManagerDataSource.java:164)
	at org.springframework.jdbc.datasource.AbstractDriverBasedDataSource.getConnectionFromDriver(AbstractDriverBasedDataSource.java:153)
	at org.springframework.jdbc.datasource.AbstractDriverBasedDataSource.getConnection(AbstractDriverBasedDataSource.java:119)
	at org.springframework.jdbc.datasource.DataSourceUtils.doGetConnection(DataSourceUtils.java:111)
	at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:77)
	... 82 more
Caused by: org.hsqldb.HsqlException: Database lock acquisition failure: attempt to connect while db opening /closing
	at org.hsqldb.DatabaseManager.getDatabase(Unknown Source)
	at org.hsqldb.DatabaseManager.newSession(Unknown Source)
	... 93 more
