[solved]: Synology Permissins on Cover Art downloading /java
When trying to change a cover art, it gives the error:
java.io.FileNotFoundException: /volume1/Music/S/Sven Väth/1998 - Fusion [CDA]/cover.png (Permission denied)
error occours, when no/wrong permissions for the madsonic server are given to you media library-folders. This could be for some early or beta packages of madsonic for your DS
Log:
[2017-03-04 13:51:11,139] WARN CoverArtService - Failed to save cover art for album 453490
        at java.io.FileOutputStream.open0(Native Method)
        at java.io.FileOutputStream.open(FileOutputStream.java:270)
        at java.io.FileOutputStream.<init>(FileOutputStream.java:213)
        at java.io.FileOutputStream.<init>(FileOutputStream.java:162)
        at org.madsonic.ajax.CoverArtService.saveCoverArt(CoverArtService.java:132)
        at org.madsonic.ajax.CoverArtService.setCoverArtImage(CoverArtService.java:82)
        at org.directwebremoting.impl.CreatorModule$1.doFilter(CreatorModule.java:172)
        at org.directwebremoting.impl.CreatorModule.executeMethod(CreatorModule.java:184)
        at org.directwebremoting.impl.DefaultRemoter.execute(DefaultRemoter.java:353)
        at org.directwebremoting.impl.DefaultRemoter.execute(DefaultRemoter.java:306)
        at org.directwebremoting.dwrp.BaseCallHandler.handle(BaseCallHandler.java:110)
        at org.directwebremoting.servlet.UrlProcessor.handle(UrlProcessor.java:211)
        at org.directwebremoting.servlet.UrlProcessor.handle(UrlProcessor.java:185)
        at org.directwebremoting.servlet.DwrServlet.doPost(DwrServlet.java:144)
To solve this, you need to grant the madsonic user (which runs the madsonic package on your synology diskstation server) the permissions to write to your media/music folders which you have configured madsonic server should use for indexing your media/music.
On your DS:
go to control-panel and edit the shared-folder, which contains your media/music-library configured in Madsonic Server-&gt;Settings-&gt;Media folders
go to control-panel and edit the shared-folder, which contains your media/music-library configured in Madsonic Server->Settings->Media folders
change the permission for the madsonic user as in the screenshot
Now the Madsonic server can download cover art and store it into the same folder, as the music/media is.
