back cover instead of fron cover shown (FLAC)
REPRODUCIBLE: Yes, on same FLAC files, but not on all FLAC files
On some FLAC files, the "wrong" coverside is shown.
The back cover of the file is shown, instead of the frontcover.
original front cover
back cover instead of front cover is shown
I uploaded an example file here. I tagged it with foobar2000 quite a while ago and it seems correct looking at the tags.
Maybe the back cover is not taken from the files tag, but from the internet?
Re: back cover instead of fron cover shown (FLAC)
You have 2 covers within your metatags.
BTW: You can add more filenames to match your covers in the right order Settings > General > Cover art files
Most of the music in our collection has at least a
front-cover
back-cover
disk-image
maybe artists art
Isnt it possible for madsonic to identify what kind of cover is embedded in the files und it just takes the first one?
I understand "You can add more filenames" to used only with such files as cover.jpg or folder.jpg or backcover.jpg, but we don't use files for covers. we embedd them into the files.
IMHO, its possible to identify the art of the cover: http://www.richardfarrar.com/embedding- ... mp3-files/
foobar2000 screenshot, where we add covers:
This is shown correctly in madsonic. The frontcover is shown.
embeding different covers via foobar2000
This wrongly shown.
example for the test file
(both seem identical to me from a Users-GUI-view. I don't had a technical look at those files)
next snapshot build try to identify the front cover-art, if no cover can be identified the first image will be used.
@Matt in your case it's fixed ;)
