Madsonic Server 6.2 Synology-DSM 6.0
Answers: 4
Has thanked: 1171 times
Been thanked: 457 times
Madsonic 6.2 on Synology
http://www.synology.com
for DSM 6.0.x only!
  • Perl
  • Java Manager 8
Installation:
  • prepare Synology hardware
  • update to latest Synology DSM 6.0.x
  • create new Volume
  • activate user home service
  • install Perl module
  • install JavaManager module
  • download latest Java JDK 8
  • upgrade Java JDK on DSM
  • reboot Synology
  • install Madsonic 6.2 package
  • start Madsonic service
  • logon as admin user
  • set system output to debug
  • check Madsonic log files
Download:
Madsonic6.2-B9280-DSM6.spk (experimental build - database deadlock issue)
  • DSM Docker
Installation:
  • install Docker module
  • install Madsonic docker image madsonic/ubuntu-madsonic-beta
Download:
  • Java Manager 7
  • Tomcat 7
Installation:
  • install Tomcat7 module
  • download latest Java JDK 7
  • mkdir /var/madsonic
  • reboot Synology
  • install Madsonic tomcat war
  • start Tomcat service
Download:
eevv
Been thanked: 6 times
Re: Madsonic Server 6.2 Synology-DSM 6.0.x
Unread post by eevv »
So this won't work on the very latest DSM out a few days ago then ?
zdunas82
Unread post by zdunas82 »
eevv wrote:So this won't work on the very latest DSM out a few days ago then ?
I would like to know that too. I am unable to install it on DSM 6.1
