I have found another podcast that doesn't seem to work with the Madsonic podcatcher. The podcast in question has unicode characters in the XML which seem to cause parsing errors. I have confirmed this by downloading a copy of the XML file locally, removing the XML characters, and pointing Madsonic at the local copy of the XML. The podcast will then process and download as expected.
I will send you a URL to the feed in question.
Podcast with unicode characters in XML do not work
- troycarpenter
- Has thanked: 28 times
- Been thanked: 50 times
huggenknubbel
- Has thanked: 4 times
- Been thanked: 1 time
Re: Podcast with unicode characters in XML do not work
Not only with Podcasts. i also get trouble with Music with Unicode Characters.
i have some Music with ä, ö, ü, "_" and so on. The ID3 Tag - Filescan doesnt list that in the Libary.
- troycarpenter
Yes, I've seen that too with the scanner. I've had to watch the log file and fix any filenames so the scanner would catalog them.huggenknubbel wrote:Not only with Podcasts. i also get trouble with Music with Unicode Characters.
