I am new to Madsonic, and have been trying it out for a few days. I am very pleased and decided to purchase premium. However, I would love to see a couple of improvements to the Moods Radio feature if time permits:
- Ability to define custom start and end years. Currently, you get pre-defined choices. For example, I would like to enter the years 2000 to 2017, etc..
- Ability to include or exclude certain Folders from the moods radio
- Ability to enable FollowMe automatically as a check box, or similar, so that we can set up continuous play back while configuring the radio
- Ability to save the radio options, as pre-defined mood radios that can be started with a few clicks
- API support to play/manage these
- Android support
Please let me know what you think of these ideas. Does it seem likely that any of these could become a possibility in later releases?
Mood Radios improvements
- These users thanked the author monadoxin for the post (total 2):
- Madsonic • Matt Zornig
- Rating: 15.38%
Re: Mood Radios improvements
really like those.monadoxin wrote: - Ability to save the radio options, as pre-defined mood radios that can be started with a few clicks
Maybe also a button to (de)select all choosen moods with one click. (to convenient start a new selection)
