Multi genre tags support
sekisushai
Been thanked: 6 times
Unread post by sekisushai » 09 Feb 2016, 15:20
I've a request on multi genre tags support.
For id3v2.4 for mp3 and vorbis comment for ogg/flac files allows and encourage multi tags.
As an example here is a quotation from vorbis comment header specification :
Field names are not required to be unique (occur once) within a comment header. As an example, assume a track was recorded by three well know artists; the following is permissible, and encouraged:
ARTIST=Dizzy Gillespie
ARTIST=Sonny Rollins
ARTIST=Sonny Stitt
So, following this tagging rules, the files could have several genre tags, for example
GENRE=Electronic
GENRE=House
GENRE=Deep House
As far as I know, only a few players support multi genre tags. So to circumvent this issues, users tag with only one genre tag with all genres separated with a separator, for example
GENRE=Electronic, House, Deep House
In Madsonic,and client apps, the mixing of genre is not supported, so for example, if a song A is tagged
GENRE=Electronic
and an other song B is tagged
GENRE=Electronic, Deep House
it will results in two genre "Electronic" and "Electronic, Deep House". Song B will NOT be available under tag "Electronic" alone. So if I start a playlist under "Electronic" tag I will never have Song B available...
However, the logic would like two separate genres in this case : Electronic and Deep House. I could find Song A and B under "Electronic" and Song B under "Deep House".
That's the philosophy behind multi genre tags support and it would be great if it was implmented in Madsonic.. :)
These users thanked the author sekisushai for the post (total 4):
MadsonicbocoHeruwarfrank2228
sekisushai
Re: Multi genre tags support
Unread post by sekisushai » 26 Feb 2016, 16:12
So far, my multi genre flac files are tagged as :
Electro / Deep House
in one tag with a slash / separator.
I've observed that server 6.0 chops the tags after slash so it will be tagged
 Electro
How do you tag currently your multi genre songs ?
Heruwar
Has thanked: 3 times
Unread post by Heruwar » 27 Feb 2016, 13:30
Would also really like to see multitag support for genres in madsonic.
Unread post by Matt Zornig » 05 Mar 2017, 06:23
++1
Genasn
Unread post by Genasn » 16 Apr 2017, 13:00
OPlayer HD could be improved to support tags in srt files. These tags are very common at subtitles.
Sample:
<i>This is a test of italic.</i> results in This is a test of italic.
<b>This is a test of bold.</b> results in This is a test of bold.
rZn
Has thanked: 9 times
Unread post by rZn » 09 Jul 2017, 09:20
+1
frank2228
Has thanked: 32 times
Been thanked: 11 times
Unread post by frank2228 » 29 Nov 2017, 23:42
+1
