There is a problem with the last release. Chromecast audio in chrome isn't working (i was using subsonic before), nothing launch, no music, nothing start...
Strangely ANDROID -> DSUB -> CHROMECAST works
WINDOWS -> CHROME -> MADSONIC -> CHROMECOST doesn't works (no sound)
If you want I can give you an access for testing... (will send you a pm)
If you want I can give you logs or anything else but you need to tell me how I can do this...
https://cloud.mevaere.fr/index.php/s/SZ ... y/download
For information my chromecast audio is working with Youtube in Chrome.
Thanks a lot,
Hope it will be solved soon,
Rémi
VERSION: MADSONIC 6.0 | BUILD: 7960
SERVLET: JETTY
SERVER: CPU: INTEL XENON | ARCH: X64 | MEMORY: 32GB | HDD: 2TB
OS: DEBIAN 8.3
SYSTEM: SERVER
INSTALLER: WINDOWS
JAVA: ORACLE JDK 1.8 ( java 1.8.0_60)
BROWSER: CHROME 48
CLIENT:
DESCRIPTION: Can't start chromecast audio
REPRODUCIBLE: YES
Chromecast not working with MADSONIC 6.0 7960
Re: Chromecast not working with MADSONIC 6.0 7960
I have made several other test :
-> It isn't working with MP3 files too
-> It isn't working on another computer
-> It isn't working if i set up the server on a non SSL port
Thanks for all
Thanks for all
Bug confirmed!
for temporary fix, please switch back to build 7860
bug fixing is already in progress
