Synology Music Library Scan Problem !!!
Aktarus
Unread post by Aktarus »
Hello everybody,
I need a little bit of your help for my new Madsonic v6 installation.
I was using an old Musiccabinet mod and want to switch with Madsonic.
All my 95000 mp3 fils are store in my synology nas and work well.
My madsonic installation is on a windows 10 computer
But when I want to add these share to my madsonic library, 0 files found and nothing in my library.
I tried to add smb share in two way without any success...
Either \\Nasname\music or \\192.168.2.186\music return anything while library scan.
But these share name are working well in other program in the same windows 10 computer
I don't think it's a synology security issue because all the share are working well with:
- My win10 computer where madsonic is install ...
- my 3 other pc. (one with the "true" subsonic v5)
- my Minix android tv (Kodi)
- My Iphone/pad
- My NeoTV550 media player
.... So, any idea of why Madsonic don't want to scan my media files ???? I really want to use this app !!!
MERCI .. and sorry for my poor english !!!!
Re: Synology Music Library Scan Problem !!!
to use a different account for Madsonic service will help you
http://beta.madsonic.org/pages/getting-started.jsp#2
Aktarus
MERCI .. MERCI ... you're my new best friend !!!
It's working well now ... I just changed the service username and everthing's fine now !!!
MERCI :thumbsup: :mrgreen:
These users thanked the author Aktarus for the post:
