https does not work
illumilore
- Been thanked: 4 times
https does not work
After following the instructions to enable https by changing the config file line for the args to MADSONIC_ARGS="--port 4040 --https-port=4443 --init-memory=300 --max-memory=1050", when accessing the https port, the web browser is never able to connect.
Re: https does not work
Maybe a typo because https port is 443 not 4443?illumilore wrote:After following the instructions to enable https by changing the config file line for the args to MADSONIC_ARGS="--port 4040 --https-port=4443 --init-memory=300 --max-memory=1050", when accessing the https port, the web browser is never able to connect.
https://your.host/ for 443
https://your.host:4443/ for 4443
only to be sure this is what you had in mind ...
illumilore
4443 is what I set the https port to be in /etc/sysconfig/madsonic, since 443 is already used. I have checked the firewall to make sure that is open. In the madsonic_sh.log, there is no mention of it running on port 4443, only on 4040.
