6.0.7450 update results in 404 error
Has thanked: 11 times
Been thanked: 105 times
Unread post by gurutech »
Just updated to 6.0.7450 and receive an "Access Denied" error when trying to get to my home page.
I'm going to try reinstalling, hoping it will work. Already tried restarting the service with no luck.
Anyone else experience this? I'm running the Windows 64-bit version...
Edit: Reinstall did not fix the problem....
These users thanked the author gurutech for the post (total 2):
taoismMadsonic
Rating: 15.38%
taoism
Has thanked: 3 times
Re: 6.0.7450 update results in 404 error
Unread post by taoism »
gurutech wrote:Just updated to 6.0.7450 and receive an "Access Denied" error when trying to get to my home page.
I have renamed my previous madsonic install as madsonic.old, installed fresh. and it seems to work fine.
These users thanked the author taoism for the post:
jake-
Has thanked: 13 times
Been thanked: 15 times
Unread post by jake- »
just to let you know: Update was painless here
PS: Thanks for the API-Emu
Edit2:
atm it is running in a loop eating all available ressources (maybe activated by enabling followme):
[2015-09-16 14:31:30,769] DEBUG AbstractDao - 2937 ms: select id, path, folder, type, override, format, data, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, mood, bpm, composer, bit_rate, variable_bitrate, duration_seconds, file_size, width, height, cover_art_path, [...] from media_file where type=? and lower(artist)=? and present
[2015-09-16 14:31:33,291] DEBUG AbstractDao - 2112 ms: select id, path, folder, type, override, format, data [...] from media_file where type=? and lower(artist)=? and present
Edit1:
FLAC is no longer transcoded for playback. Mayby because of this?
These users thanked the author jake- for the post:
Lost all my settings that way, but restored the db and db.backup folders and all is well again (minus a few bugs I've found, which I will post in the bug report forum....)
