[Solved] [6.0.7110] URL settings ignored in properties-file?
Mission accomplished!
Heruwar
Has thanked: 3 times
Unread post by Heruwar »
:geek: Background: I've been running Madsonic 5.2.5420 for a while with the following URL redirection settings:
UrlRedirectContextPath=madsonic
UrlRedirectionEnabled=false
MadsonicUrl=https\://mydomain.com/madsonic
Together with appropriate apache reverse proxy settings so that I can access my madsonic server on https://mydomain.com/madsonic, and it has been working great for a long time.
I just checked out version 6.0.7110 and tried to migrate these settings, but keep getting redirected to http://127.0.0.1:4040/login.view whenever I access the https://mydomain.com/madsonic URL. With version 6.0 I'm using these properties:
UrlRedirectCustomUrl=https\://mydomain.com/madsonic
UrlRedirectType=CUSTOM
The "UrlRedirectCustomUrl" and "UrlRedirectType" settings seem to be new in 6.0 and created from the Web GUI under Settings > Network, at least my old config didn't have these listed. I also tried adding the old "MadsonicUrl=https\://mydomain.com/madsonic" option, but that didnt seem to make any difference either.
Has anyone managed to get this working in versions after 6.0?
It feels like I've tried all variations of the new and old options to no avail. Any tips on what I'm doing wrong here? :geek:
These users thanked the author Heruwar for the post:
Heruwar
Re: [6.0.7110] URL settings ignored in properties-file?
Some additional information:
When I try to use the Web GUI and go to Settings > Network and try the "Use custom URL" option I get this SSL error message:
Also checked with some SSL cert validation tools, and can't find any errors with my certificate. None of the madsonic or apache logs show any errors either.
Since Build 7110 the correct settings for custom sharing are:
UrlRedirectionEnabled=true
UrlRedirectCustomUrl=http\://localhost\:4040
You can ignore the results from the Madsonic backend in your frontend,
without your certificate the backend can't connect, it's only for testing purposes.
Heruwar
Heruwar
Thanks for the feedback.
I just did some more research, and the root cause for my problem is that I can't get madsonic to become available at http://localhost:4040/madsonic like before.
Is the "UrlRedirectContextPath=madsonic" option renamed, or no longer available?
Is it possible to get the same effect some other way?
I also tried with these settings but it didn't seem to make any difference:
UrlRedirectCustomUrl=http\://localhost\:4040/madsonic
Heruwar
Apparantly the command line option to madsonic.sh still works, even if the option in the properties-file doesn't.
So setting MADSONIC_ARGS="--context-path=/madsonic" in /etc/default/madsonic solves the problem for me.
for clarification:
This feature never worked like this!
UrlRedirectContextPath is for the routing to your name context Path --> username.madsonic.org
but the contextPath for the servlet can only be set as you mentioned in your post before
-Dmadsonic.contextPath=/madsonic
recky
Re: [Solved] [6.0.7110] URL settings ignored in properties-f
Unread post by recky »
Hi guys,
sorry to be a bother, but could you sum up again how to do this exactly? I'm using 6.1 of DSM 6.
I use a DSM6 native reverse proxy rule which is configured to https://madsonic.domain.com. But I too get redirected to https://madsonic.domain.com/login.view and then a 404 not found page.
thanks so much in advance!
