[Solved] Java version crashing Madsonic server
Posted: 10 Aug 2015, 18:43
by gs33333
Java version was updated yesterday (9-Aug-2015) and now the Madsonic server crashes
Please help. The error information is in the attached text file. Thank you...
Re: Java version crashing Madsonic server
Posted: 27 Aug 2015, 19:12
by gs33333
I managed to solve the problem.
I looked at the log files and saw many errors related to database access. I had to rebuild the database - stop the service, delete C:\madsonic\db and restart the service. It rebuilt the database and now it runs fine. The log file shows no errors so far.
Apparently the problem was not related to Java but to lack of disk space or something similar, and it incidentally happened just after some Java update.
