[Solved] Java version crashing Madsonic server
gs33333
Unread post by gs33333 »
Java version was updated yesterday (9-Aug-2015) and now the Madsonic server crashes :(
Please help. The error information is in the attached text file. Thank you...
Err.txt
(7.75 KiB) Downloaded 762 times
gs33333
Re: Java version crashing Madsonic server
I managed to solve the problem.
I looked at the log files and saw many errors related to database access. I had to rebuild the database - stop the service, delete C:\madsonic\db and restart the service. It rebuilt the database and now it runs fine. The log file shows no errors so far.
Apparently the problem was not related to Java but to lack of disk space or something similar, and it incidentally happened just after some Java update.
These users thanked the author gs33333 for the post:
