yum install java-1.8.0-openjdk-devel.x86_64Code: Select all
[root@server madsonic]# !1014
sudo update-alternatives --config java
There are 2 programs which provide 'java'.
Selection Command
1 /opt/jdk1.8.0_25/bin/java
*+ 2 /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.31-1.b13.el6_6.x86_64/jre/bin/java
Enter to keep the current selection[+], or type selection number: 2
[root@server madsonic]#Code: Select all
[root@server madsonic]# java -version
openjdk version "1.8.0_31"
OpenJDK Runtime Environment (build 1.8.0_31-b13)
OpenJDK 64-Bit Server VM (build 25.31-b07, mixed mode)
[root@server madsonic]# service madsonic start
Starting madsonic ...
Started Madsonic [PID 3464, /var/madsonic/madsonic_sh.log]
[root@server madsonic]#http://pastebin.com/UWNT0ekL
When I go to localhost:4040 then site says:
HTTP ERROR: 503
Problem accessing /. Reason:
Service Unavailable
Powered by Jetty://-- EDIT --
Seems like db have screwed up, I deleted everything in db folder (/var/madsonic/db) and everything working now. I leave info if some one cold use this info in future
