I saw in the xbmc plugin the option to disable transcode, so i think it's possible to disable it in ms, but i don't know how, and wich files i have to modify
Could you please give me some input where i have to look and, if not so hard, how to add a check to the dlna page to enable/disable it easily?
thanks a lot
Tk
