I've used a guide to install madsonic and managed to get the service up and running.
When I write (SSH): sudo madsonic the output is:
Started Madsonic [PID 2462, /var/madsonic/madsonic_sh.log]Code: Select all
Exception in thread "main" java.lang.UnsupportedClassVersionError: org/madsonic/booter/Main : Unsupported major.minor version 51.0
at java.lang.ClassLoader.defineClass(ClassLoader.java:643)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:277)
at java.net.URLClassLoader.access$000(URLClassLoader.java:73)
at java.net.URLClassLoader$1.run(URLClassLoader.java:212)
at java.net.URLClassLoader.findClass(URLClassLoader.java:205)
at java.lang.ClassLoader.loadClass(ClassLoader.java:323)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:294)
at java.lang.ClassLoader.loadClass(ClassLoader.java:268)
Could not find the main class: org.madsonic.booter.Main. Program will exit.Code: Select all
java -version Code: Select all
java version "1.6.0_32"
OpenJDK Runtime Environment (IcedTea6 1.13.4) (6b32-1.13.4-1~deb7u1+rpi1)
OpenJDK Zero VM (build 23.25-b01, mixed mode)What did I do wrong? Any help or ideas?
Thanks,
krijeck
