Unable to launch madsonic (Debian Wheezy)
b1555457
Unread post by b1555457 »
I installed java 7 version 1.7.0_65 along jre-7-headless then installed madsonic 5.1.5200, however when it finishes and tries to start, or I try to manually start it, it doesn't start. My madsonic_sh.log shows this
Exception in thread "main" java.lang.UnsupportedClassVersionError: org/madsonic/booter/Main : Unsupported major.minor version 51.0
        at java.lang.ClassLoader.defineClass(ClassLoader.java:643)
        at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
        at java.net.URLClassLoader.defineClass(URLClassLoader.java:277)
        at java.net.URLClassLoader.access$000(URLClassLoader.java:73)
        at java.net.URLClassLoader$1.run(URLClassLoader.java:212)
        at java.net.URLClassLoader.findClass(URLClassLoader.java:205)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:323)
        at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:294)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:268)
Could not find the main class: org.madsonic.booter.Main. Program will exit.
Dylansama
Re: Unable to launch madsonic (Debian Wheezy)
Unread post by Dylansama »
Perhaps you missed a step in installation for Debian?
As the main exception really seems to be it could not find the Main class in the booter...which is really bad. Not the java version so much.
However just to be sure you do have the correct jre/jvm setup what is the output of?
java -version
How are you starting madsonic?
These users thanked the author Dylansama for the post:
Robin0815
Unread post by Robin0815 »
#!/bin/bash
sudo apt-get install openjdk-7-jdk openjdk-7-jre
sudo update-alternatives --config java
# Set to 1.7
cd /opt && wget $url_to_latest_madsonic_version
sudo dpkg -i 20141017_madsonic-5.1.5200.deb
These users thanked the author Robin0815 for the post:
3tcetera
sIRwa2
Been thanked: 6 times
Unread post by sIRwa2 »
What i always forget is that Debian comes standaard with JAVA 6, so you have to switch to 7 manually using
These users thanked the author sIRwa2 for the post (total 2):
3tceteraMadsonic
Rating: 15.38%
TYI
i add some java installation notes to the documentation
http://beta.madsonic.org/pages/installation.jsp#java
