An easy way to install your own certs
apastuszak
Unread post by apastuszak »
I pay for an SSL cert for my domain name. I have a cert and an intermediary cert. I'd like a way to add the certs to my Madsonic install without having to crack files open and insert certs.
These users thanked the author apastuszak for the post (total 3):
Larsjdubsotaylord1984
Rating: 23.08%
Lars
Has thanked: 23 times
Been thanked: 23 times
Re: An easy way to install your own certs
Unread post by Lars »
apastuszak wrote:I pay for an SSL cert for my domain name. I have a cert and an intermediary cert. I'd like a way to add the certs to my Madsonic install without having to crack files open and insert certs.
it would be a great feature if one could insert his own certificate via a simple input field in settings! you have a big +1 from my end!
cheers, L
